Have loaded the latest Reader software update but the PRS-600 still cannot be found by the computer. I have done all the recommendations by the 'Troubleshooter' section of the User Guide.
HELP! I cannot bear to be without this wonderful device.
Message was edited by: savernakebiz
Are you using the correct software, try this http://tinyurl.com/6ty2han
Message was edited by: sehuxle
