I have accidentally deleted some of the folders in the root of the internal memory.
Now for example, I have no dictionary! When I select either of the two dictionaries listed, the PRS-600 reboots and I'm still left with dictionary = none. Again if I select either of the 2 dictionaries available, the same thing happens again.
Where can I download the files/folders that existed in the root of the internal memory?
Or specifically, can someone zip and email me the dictionary folders, so I can extract them to the root internal memory?
My email address is [email protected]
Thanks,
Richard Abramson
Hi
I am sorry to say the only way to resolve the on-board software it to return the product to Sony, it will have to be reset to factory condition and this cant be done by a user
