Whenever prs-t1 is connected with reader software,it takes a very long time to synchronize even no modifications are made. There are less than 20 books because I got PRS-T1 several days before. Should an improvement on sychronization speed be taken for reader software?
hi
you may find that the free calibre software works better. i must admit i have just about given up on the sony software as it does indeed take forever to sync. search for calibre on google or read posts on mobile read forum
thomas
Check you have the latest version - or Calibre your way around....:smileyhappy:
