I downloaded an audio book from Audible. I can't get into my reader library. It's in my itunes. Any ideas please.
Hi, you would need to drag and drop via Windows Explorer, you may not be able to though dependant on the bit rate and codec used on the Audio book as they are designed for a specific product range, this you will need to check on the Audible web site.
