Hi,Bought the wife this reader PRS-350 & the trouble I have is at night when you are reading it you have to keep the room light on or you don't see anything 😕
I would think this Pocket has a setting on it to turn a light on it like the way say you're iPhone would have so you can read it in the dark.
Any help more than welcome,Thanks.
Hi Tigerplank,
unfortunately the screen has no backlight so there isn't an option to illuminate the screen..:smileysad:
There a case for the PRS-350 (PRS-ACL35) which includes a light..:smileywink:
Hi Tigerplank,
