I have a prs-t1 reader, an 2 computers. And when I syncronise my reader on one computer, all the books which came from my other computer diappears ! I use the softwere which came with my reader.
How shall I do to fix it ?
Or is it normal, some sort of a system to prevent book trafic ? Should I then put all my books on both computers ?
thank you in advance
Cencerly
olofskivarp
I think you'd need the books on both computers to avoid the problem.
Usually when syncronishing, the items on the PC are starting point. So the reader will look to what is on the PC and match that.
The best option is not to synchronise at all. When you add a book to your PC library move it to your reader manually.
Or use Calibre on both computers ?
Easy to install, free, and excellent system.
