I'm very new and I bought my first e-reader sony PRS-T1 2 days ago.
What I'm interested in this e-reader is that I can highlight those texts which I think important.
Sometime I write notes as wel.
I would like to know HOW can I export all these highlight texts and my notes?
I've done some reserch with google but it seems it is impossible!!
It's hard to believe because if I can't get my notes as a summary, I will be so disappointed.
Anyone knows about this issue?
Thanks in advance!
I'm in the same situation!!! Any answer, please.
hey,
it is possible to get the annotations via the reader for pc software. if you open the books transfer them to your computer and then open them - you will find on the lower end of the window the second item from the left the export function.
(this miracle seems to be quite new to most of the customer support and none of them will tell you...)
HOWEVER: i would NOT DO THIS! as the sony reader for pc software is the worst piece of software i ever encontered. it crashes constantly (deleting parts of you books etc) - and in my case it joust deleted a 500 page book with very important annotations (about 2 months of work gone and no possibility to rebuild them...)
so all yell at sony for serving such indegestable dishes to their customers!
you may try noteworks:
http://themediahost.de/noteworks/
Does all that.
Nachricht geändert durch slnread
