At present, all my books appear in alphabetical order of the author's first name, so:
Charles Dickens
Charlotte Bronte
etc etc
Can I change this so they appear in order of teh author's surname, eg:
Dickens, Charles
Eliot, T S
etc etc
I was able to do this (using Calibre) on my PRS-505 but can't seem to do it on the 350. Is it possible?
Richard
Hi Richard,
I don't think this is possible using the readers software as it only sorts by authors first name for some strange reason..:smileysilly:
I'm not sure if you can do this on the 350 using Calibre..:smileyconfused:
The also PRS-650 also sorts them the wrong way around. Maybe this could be fixed by a firmware update?
