I bought an ereader last December. The laptop I use to manage it died recently. I have lost the details of my Sony account - the email address I think I used is no longer available to me, so I can't authorise my new laptop rendering it effectively useless. What can I do?
Thanks
Message was edited by: epzcaw
I think Drumzman's your best source of help here - try a PM if he doesn't pick your query up....
I took your advice, and found that Druzman has already provided the solution to my problem. All up and running again now.
Thanks to you both.
