I have downloaded some books ro my e-reader, when the reader is connected to my pc i can see the books on the pc, but there aren't any icons on the reader, any advice welcomed.
Regards,
Derek.
With the reader disconnected you're saying that no books are showing on the home page? Yes or No
Are they showing if you select all your books or go into collections. If on the home page you select 'books see all' how many books does it say you have on the reader and is this different to those on your PC?
As suggested you should install Calibre software, then add a free book and does that show on the home page.
With the reader disconnected on the home page is showing the correct number of books installed, what is not showing is the shortcut/icon to load the books.
Looks like I will need to look into "calibre"
