Hey,
Ok... I have a new PRS-T1... I have registered with Sony, Registered with Adobe, downloaded and authorised ADE, installed R4PC. I have some free ebooks too... but this is as far as I got...
Reader and ADE can see all my ebooks and I can open them on the laptop... however the laptop doesn;t seem to recognise my PRS-T1... and I cannot figure out how to put my ebooks on it... it also says that the reader is not authorised for ADE...
ANy help would be great!
Thanks
Message was edited by: -Cass-
Edited for personal details
Is your laptop USB'd direct, or are you using a hub ?
'Cos you should be up and running.....
You need to get acknowledgement that reader and laptop are communicating (My Computer) before interaction will work.
Check PM's as well....
