Hi
I am looking for a charger for my PRS-505, that i can use in Europe (Sweden).
Charging on the computer takes power and the reader is half empty again when it has uploaded after charging.
Use a big memory card in my reader.
There is no adapter available here.
AC adapter ACS-5220E seems only for USA, and PRSAAC1 is not compartible.
Any options?
The ACS-5220E was the AC Adapter sold for Europe also: -
http://www.sony.co.uk/product/rda-other-reader-accessories/acs-5220e
There are some available still here in the UK but you will have to Google for a local supplier: -
http://www.amazon.co.uk/Sony-Adaptor-Reader-eBook-ACS5220E-EU8/dp/B002BZYB2K/ref=pd_cp_computers_3
Hi
Thank you Blencogo.
I was able to order an adaptor from Amazon.de, so now my charging problem should be solved by next week.
