I wanted to use my phone again for an backup phone, but the process went different what i expected.
My Sony Xperia E1 D2005 is stuck on Sony logo when I boot the device.
I saw on multiple forms that i need the PC Companion and using the repair option. I downloaded it right away but when im on the 3rd Step when i need to connect the device by usb while pressing volume down button it shows an green LED, but nothing did show up. And it didn't continued to the next step.
I have tried to take out the battery, put it on again, plug while pressing volume down. But again an Green LED, but nothing helps. Also when connecting the device to my pc, my pc doens't recognise my phone.
I don't know what to do now, any help will be appreciated.
1.) charge your device for 1-2 hours using the wallmount adapter
2.) try to perform software repair using Xperia Companion again, make sure to follow instructions carefully. know when to press the buttons and when to release,
3.) try to use different port.
4.) reinstall xperia companion
Thanks for the response, i will try it today and keep you up to date.
