After i loaded a new custom bootanimation to the data/local folder, im unable to turn on my phone. On pressing the power button, Sony logo appears and after that its all black. The phone is detected on my windows machine though.
Is there any way i can reset without using flashtool? Physical buttons would be great. i dont mind losing the data.
please help!
bootloader is locked.
yes, phone is rooted.
not that I can think of, either flashtool or SUS should solve this bootloop issue.
SUS worked. Took a long time to download on my slow connection but its okay now. Since i am going to be tinkering around and this may happen again, is there anyway that i can avoid the downloading process in the future? save the download?
or how to make a full nandroid backup? so far ive been googling like crazy but cant seem to find any.
