Hi everyone! Thanks for the advice! after uninstalling, installing 2 or 3 times, checking all the settings, I found the problem, for some weird reason a few of my contacts (those that I used the most) had the a "custom notification ringtone" checked, when I un checked them in the individuals contact settings everything started to ring perfectly and just ones, with the right notification sound!
Thank you guys!
