How to disable vibration on E5 F3311
Как отключить вибрацию на E5 F3311
Are you trying to disable vibrate notification on ALL notifications or an specific app?
All vibration
Всю вибрацию
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
set the phone to do not disturb mode
OR
open each app that you are getting notifications from > settings > notification > disable vibrate notification > repeat as needed
