Hello. I've been this problem popping up ever since I got the Amino app from the playstore. I've used the Xperia Companion to try and repair the phone but this has not worked. I've also deleted the updates from the Google app and stopped it from updating plus restarted after doing so. What else can I do?
I have attached updated, which is to be made for you resume for your information In the above subject Ihope you can help with the problem. Simply do, possible that you could use reset phone 📱 and restore. the phone system with campany settings
System ui has stopped working. How to solve this problem?
