My Sony e5 does not turn off the Display during calls, thats why i change settings wird my ear on the Phone during calls... Thats nasty, in anybody hast a tip for Me - that would be great!
Hi, Thanks for Your answer, yes, exactly: my phone screen does not go black when i hold my phone up my your ear.
I tryed the same function in Phones safe Mode, But without success... The Screen was still active during calls with Phone at my ear.
Whats wrong? Is the sensor broken?
Hi @Jubi1,
Thanks for clarifying that!
Next I would advise trying a software repair using Xperia Companion, if this is a software issue that should resolve it for you.
If you are still having problems after that, I would advise getting in contact with your Local support so they can arrange an assessment and repair for you.
Good luck
