I can't power on my device. It shows a red battery icon when I try to turn it on and then shut downs automatically. This process keeps on repeating. When switched off and connected to pc , the charging light keep turning from red to green and vice versa after few minutes. Due to this I am not able to use Software repair process of pc companion as it throws an error midway when the charging light turns red.
Is there any way to revive this phone or is it completely dead ?
I had the same problem with my E4 and i had to change the battery to an authorized service. There is no other way to make the phone run again.
