My Xperia E is working properly,but there is one problem - in android topbar there is written pending for sim 2.I read app info and it is created by the programm - R2R client.
how can i fix this ? or does my phone need something ?
check your sim ...try other sim
MY MOBILE NOT CONNECT DUE TO R2R CLIENT HAS STOPPED
Imhaving the exact same problem on my Sony Xperia Z3 Compact. Could you send me an email if you get a reply from sony? It would be much appreciated.
Are you having problems connecting to your network? Like to use your data and call people?
how you solved your problem with downloading Internet & MMS setting ?how you solved your problem with downloading internt & mms setting?
Hey there, I'm not so much experienced with this stiff but I'm pretty sure that's a network/human error? Unless like me you couldn't find the extension to make your sim card bigger? I've even gone through the effort of getting a screen shot from my network of the human error (meaning you forgot to do something, I just don't want to be rude about it
I have Sony Xperia phone. It is working good but when internet open proble rise " R2R client stopped. I hve chaned sim also but problem still persist.
