I tried using Smart Connect (on my E4G) at night - to turn off wifi and data at night and turn them back on in the morning. The wifi part worked flawlessly. Data connection do get disabled at night, but wont re-enable in the morning - I have to manually enable it. Any workaround?
With SmartConnect on, phone loses only 4% charge overnight, otherwise it is 10-12% - it would be wonderful, if it is completely automatic.
Thanks,
Anoop
There was a similar question, regarding low battery mode, you will have to enable it manually.
Thank you. Guess it is an OS restriction.
Maybe Sony should put this too in its Stamina options.
Anoop
