Hi im new and I just bought a Xperia E4 and I tried to search for the small app but couldnt find the soudn recorder 😧
Hi kortik425,
As far as I know, Xperia E4 does not have any preinstalled sound recorder. You may need to download an application for this via Google Play. Check out the following one:
https://play.google.com/store/apps/details?id=com.sonymobile.androidapp.audiorecorder
Hi kortik425,
Open the messaing app > attachment > record a sound
if you want to record something else you should check the playstore
Thank you very much for the replies... I downloaded a recorder from Google play.
