Hi, I have xperia e5. I cant charge battery at this phone... When switch off the phone charge ok, but if is on dont charge... I try on diferent chargeres..... How I can fixet my problem?
when you say different chargers, do you also mean different USB cables?
if you have tested different cables and wall chargers, then you will need to contact your Local support to get it inspected.
