hello every one, how is going well this is it, i've got problem with my sony E4 dual sim [ E2115] i can not use it correctly , you know screen goes off for you know battery saving ot ok , but when i want to wake it up, i have to press power button several time ant yet its not working nice , i guess something wrong with software , cause i am not able to install or update any App, its working on installing but nothing work after several .
what should i do ?
- well you know Except reset factory , if u plz , [ i prefer to do sth else u know , inested of lossing all data ]
retry the updating for 3 times , and its done ,
i'm not sure where the problem was , but its all gone for the moment.
tanx guys .
