This morning the power button on my Xperia E5 stopped working completely. I've tried holding it in and just pressing it in but it does nothing. I know the phone is still on because I'm getting notifications through to it. If i plug it in the screen lights up as well. It just seems like the power button isn't responding to anything. I can even hear the click when I press the power button in but it's still not working at all.
this seems to be a hardware problem. I suggest to take to your local service center Local support
i cant even hear it click i was going tty a factory reset but im thinking i will be unable to power it after unless it does without me using power button
i had this on my E5 all you have to go is hold the power button and the volume button it will vibrate 3 times then wrk perfectly again
i have tried the above and it doesnt vibrate in fact it does not push inwards at all i think once it drains the battery i will be unable to
