when i set pattern lock sony xperia E is not showing lock screen wallpaper it is showing only home screen wallpaper is there any way to make visible lock screen wallpaper even when we keep pattern lock
there isn't a way to do so unless you install a different lockscreen app
ok i thought so anyway if there is any sony update for that please inform me in future
p.s
i dont like to install third party softwares for small things
Try this
remove the pattern lock > change the lockscreen wallpaper > now add the pattern lock
Don't forget to give Kudos
i removed pattern lock and kept none now changed lock screen wallpaper and then again added pattern key still the same
This does work with my Xperia Z, but it doesn't seem to be the same for your Xperia, you will have to download another app (lockscreen app)
