Hi
anyone can tell is there any NFC facility for xperia e4? i am not meaning xperia e4g. because sony xperia video mentioned e4/e4g have NFC. but when I checked the e4 website they didnt mentioned NFC. but e4g have NFC. please help me.
thanks
Hi amd_2012,
With the information I have been able to obtain, this device does not seem to have NFC, I will however double check for you.
Hi amd_2012,
It doesn't seem to have NFC @Jake-SonyXperiaSupport you are right
http://www-support-downloads.sonymobile.com/e2105/whitepaper_EN_e2104_e2105_xperia_e4.pdf
