Recently I purchased Xperia E dual and since the begining the people whom i call complain about low volume or they can not hear my voice. Other functions are fine.
I tried using Diagnostics but no improvement so far.
Has anyone faced such problem with the Microphone and how to resolve?
Look in call settings for slow talk and microphone noise suppresion,disable them.
I'm also facing similar problem in my Sony Xperia E1 handset...Did you get any solution..?
im having that same problem i tried disabling noise supresion but it didnt work i really need to fix this can someone give me a solution that works p.s i couldnt find slow talk so maybe thats why it didnt work
To find the "Slow talk" option go to Settings > Call settinfs > Slow talk
By the way I dont have any problem with my microphone for my Xperia E1. And for me the Microphone and Ear speaker is quite good.
Anyway, I have the Slow talk option disabled. But I have the Microphone noise suspension enabled. And it works fine for me.
I think if you have serious issue with your Microphone you should contact service center.
