Hi everyone, just bought my Xperia E5 I had problems with the microphone, in fact I had to restart the phone. Then it stopped functioning completely (which led me to put the headphones every time). I have reset the phone several times but did not give results, I also tried using the Xperia companion program to reinstall the software. After using the tool I noticed that during calls the microcontroller only works when handsfree. For videos it works only if the device is placed horizontally, while for vertical no (very strange thing). When I try to use the audio recorder voice record I see 2 bars on one line and 2 on the other (they hear only buzz). I tried to send it as a guarantee but I was asked for a budget of 135 euros to make it run due to tampering because I had changed the display. I say the microphone has stopped working before changing the display. What does this depend on?
GT
