Não consigo usar o cartão de memória como fonte de armazenamento principal sempre vai pra memória interna primeiro quero definir o sd cara como principal como faço.
I can not use the memory card as main storage source always goes to internal memory first I want to set the sd as main head as I do.
GT
Hi @Fl5, welcome to our forum!
Your question has been translated to English as this is an English only forum.
There is no setting/feature in the device that allows you to download/install applications directly on the SD card, you will need to move them there after they have been installed. Do note that all apps can't be transferred to a SD card as this is up to the developer of the application to add support for.
If you go to Settings > Apps > SD card, here you should be able to see if you have any applications that can be moved to the SD card.
I hope that answers your question!
