J'ai un nouveau téléphone 📱 et je voudrais conserver les messages que j'ai écrit sur l'ancien.
Comment dois-je faire ?
Merci d'avance pour l'aide
I have a new phone 📱 and I would like to keep the messages I wrote on the old one.
How should I do it ?
Thanks in advance for the help
GT
Hi @Maïs,
This is a international community and your previous post has been translated in to English using Google Translate, please keep all future posts in English so that other users may more easily understand you.
You can transfer data from a old phone to a new Xperia device either by using the transfer function in Xperia Companion or you can use the Xperia Transfer Mobile application.
To transfer your data using Xperia Companion you first need to download Xperia Companion to a PC or Mac, click the Xperia Transfer option and follow the instructions on your screen.
If you choose to use the Xperia Transfer Mobile app you first need to make sure it is downloaded on both your devices. On some Xperia models like Xperia E5 the Xperia Transfer app is pre-installed. You can find it if you go to: Settings > Backup & reset > Xperia Transfer Mobile. Then open the application on both your devices then follow the instructions given in the app.
Let me know how it goes.
