Bonjour,
Avec un Xperia E1 je n’arrive pas à le régler pour entendre un son lors de l’arrivée d’un SMS.
Merci pour toute information.
Hello,
With Xperia E1, I can not set it to have a sound when an SMS is arriving.
Thank you for any information, I cannot find in User Guide.
Hello
I just solved my problem by using multiple informations !
Thank you for your comments and probably soon.
I think the phone is not very easy to use !
@ + reilo
Settings-sound-notification sound.
Bonjour,
Et Merci pour ces orientations. Cependant, je n’ai pas obtenu de son lors de plusieurs essais d’envoi de SMS.
Ai-je oublié une action ?
Réglages – Son – sons des notifications – choix d’un son – (Xperia ) – OK.
Merci de corriger ces actions.
Hello,
And thanks for these informations. However, I did not get a sound when several sending SMS trials.
Did I forget one action?
Settings - sound - sound notifications - choice of sound - ( Xperia ) - OK.
Thank you to correct these actions.
Also check Settings > Volume to be sure you have enough volume on your ringtone.
Hello
I just review your propositions and I finally found the solution. !
Many thanks to you all !
And so, I could choose the ringtone !
Pouvez vous me donner la solution j ai le même souci merci
Can you give me the solution I have the same concern thank you
gt
