Hello. I have trouble. I get NAC from Vodafone. After used NAC my phone showed window - Sim network unlock PIN and i see information SIM/RUIM is Perso locked- Emergency calls only.
Hi @mada2, welcome to our forum!
If your phone is locked to a specific service provider (operator) you will need to contact them in order to get a code to unlock the network lock on your phone.
Do not enter any wrong codes because you will only have a limited amount of tries.
Let me know if that helps!
Hi Jonas, i have the same problem, But in my device is "[X] Network 0 " . Soo i probably typed the wrong unlock code in the past, but NOW I HAVE THE CORRECT CODE (ee sent me
), so how can i fix it???
sorry my english, i'm italian
Hi @Itaschetto,
In that case you will need to get in touch with your Local support team for further assistance with this since you have no attempts left to unlock your phone.
I hope that helps and best of luck!
remove SIM network unlock
Hi @900w, I have answered the private message that you sent me, so please take a look at my reply there!
