Spam and stopping calls from dodgy callers
Hi @Justkev,
I'm afraid there is no default setting to block a number from contacting you. What you can do is set so that so that all calls from a contact go directly to voicemail. To do so, go to: Contacts > Contact name > Tap the pen icon in the upper right corner > Tap the three dots (...) > All calls to voicemail.
To completely block a contact or number from contacting you I recommend that you check Google Play store for a app that can do this.
Let me know if this answers your question or if you find a good app that does what you want!
hello there pleas help me block callers on ma phone,am using sony xperia c2305
