Hi @Bubba5
You can change the clock on your Xperia E5. To do so you press and hold on your home screen where you have no icon. Then go to widgets and clock. Here select the clock you want on your home screen, press and hold on it then drag it where you want on your home screen. To delete your old clock press and hold on it, then pull it up to Remove from home screen.
Let me know if there is anything else you are wondering about!:smileyhappy:
Hi @Bubba5
Great to hear it's working now @Bubba5!
If you got any other questions don't hesitate to ask!
