I would like my phone to go silent at night, but without my having to manually silence and unsilence it every day. Google suggested that I use the "do not disturb" option, but I can't find it anywhere in the settings. Does that option not exist for xperia e4? What alternatives are there?
Hi @Timrath
Unfortunately the version of Android your handset will be running does not have the Do Not Disturb function incorporated.
You may be able to find an application on the Play Store that performs a similar function to the Do Not Disturb feature so you do not manually have to silence the handset each day.
Good luck
