Hello
Is there any ways to install clockworkmod on sony xperia e (c1504) with locked bootloader?
where would that be on XDA as I've checked and see that it says it must be unlocked
If your scared about unlocking bootloader you shouldn't be even talking about Cwm
Cwm needs kernel replacement which needs unlocked bootloader
And also what are you planning to do with Cwm on locked bootloader..... Pretty much everything cwm needs unlocked bootloader
So you have read that you can for other models but not for your Xperia E - My Z1 has CWM with a locked bootloader
If interested this thread has a list with links to most thing Xperia E and the nature of your topic
I'll go out on a limb here and say yes purely based on that my Xperia Z1, S and Tipo do the latter been a low end entry level phone from 2012 so I would assume the new phones will
