Hi argy233,
Welcome to the community,
In this case, I would suggest trying to clear the camera application from the apps section.
Menu > Settings > Apps > All > Camera > Clear Data.
I hope this helps.
Can you tell which one helped? It is for future reference.
I am glad you were able to resolve this issue, but I agree with Alexdon, are you able to supply this information?
That would be a fantastic help to us
Great,I am glad it worked.
