Hi Sony Team,
May i know how to block the particular caller.
Thanks,
If you save the number as a contact in the phonebook and then edit the contact you have a checkbox at the bottom for "Send calls directly to voicemail". Enable this to block calls from the number.
Hi Sony Team,
How to Unblock phone number
how to go to the restricted list
There is no option to block. How did you block someone?
Yea,you can block the call for paritcular numbers by following these simple steps.
Suppose you want to block a number <9876543210>
If <9876543210> is already saved in your contacts under any name storing multiple phone no.
1. First remove <9876543210> from there.
2. Create new contact with <9876543210> under a different name ,say<xyz>.
3. Go to menu which is at the top right corner,there you will get a checkbox for "All calls to voicemail",mark that checkbox.
4. Click <Done>.
If <9876543210> is already saved in your contacts under any name <abc> storing single phone no <9876543210>.
1.Edit <xyz> in your contacts.
2. Go to menu which is at the top right corner,there you will get a checkbox for "All calls to voicemail",mark that checkbox.
3. Click <Done>.
Call Blocking
Block Calls from a Phone Number:
what if i dont wish to receive voicemailfrom this contact
Since the topic has so many views:
Go to "Play Store" and install "Calls Blacklist".
Then you can block anything.
Have a nice day
