How do I block calls please
Hi @AJ2403, welcome to our forum!
If you want to block calls you will need to use a third party application from the Google Play store as the Xperia E5 does not have any setting for blocking calls.
You can however save the number as a contact and change a setting so all calls from that number goes directly to your voicemail.
Let me know if that helps!
