Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I suggest you remove the battery and insert it again. Without powering on the phone, connect it to the charger and let it charge 3-4 hours or until you see that the battery is full. If there are no improvement after this, let the battery discharge fully and repeat the above process.
where to get ek dual D2105 original baterry .
