You could also take a look at the following topic:
Anytime
My e1 only stays charged for 8 hours in standby how can this problem be sorted out ?
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
First of all, check what is draining battery under settings > power management > battery/battery usage.
