x
Avast causes slowness
SOLVED
rajinraj
Visitor
HI... I am rajkumar from India. I am using the phone since 6 months. I had problem with slowness but when i removed the Avast antivirus the slowness and restart problem was sloved.
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.RO.title
_alexdon_
Expert
Most of the time,antivirus or task killers can cause problems.Good to know it is fine now.
alexdon
6 REPLIES 6
_alexdon_
Expert
alexdon
profile.country.GB.title
Uliwooly
Expert
Indeed, I don't recomend antivirus for that and other issues, such as, connectivity issues, apps crashing, etc.
daktaryxperia
Visitor
the same for me, firefox was so slow and froze after a few minutes
after frozing avast with titanium backup, navigation is possible again
did you tried another antivirus???
Uliwooly
Expert
I haven't seen any other antivirus that doesn't create some of this issues
rajinraj
Visitor
No i do not have any antivirus now...
Sachin4u
Visitor
But is it really okay to not have a security app in your phone. What if we catch a malware while surfing or installing an app. It will go undetected.
