NEW to the Sony Walkman® range
profile.country.GB.title
_J.G.M_
Community Team
Community Team
464  Views
Sony introduced two new premium music players – the NW–WM1ZM2 & NW-WM1AM2, raising the bar to new heights in High-Resolution Audio listening, to satisfy the most demanding audiophiles.
Designed to immerse you in sublime, nuanced sound, the NW-WM1ZM2 has been fine-tuned from years of audio mastery and crafted from the very best materials. This new addition sets a new benchmark for Sony’s award-winning signature series, offering an exquisite listening experience in an ultra-premium design.
The NW-WM1AM2 allows you to completely lose yourself in high-quality audio with a richer, smoother and more expansive sound field compared to its predecessor.
Both music players let you download and stream from endless catalogues of music with Wi-Fi compatibility, taking your listening enjoyment to the next level.
Extraordinary sound begins with exceptional components
Throughout the history of Sony’s premium range music players, audio mastery has been accomplished through a combination of meticulous assembly of exceptional components. The NW-WM1ZM2 and NW-WM1AM2 are products of this philosophy.
Purer materials for a purer sound
The NW-WM1ZM2 has a 99.99% purity (4N) Gold-plated Oxygen-Free Copper (OFC) Chassis. This realises a stronger digital ground and higher rigidity, enabling clear, expansive sound, so you can experience each instrument as if it were performing live.
The NW-WM1AM2 uses an aluminium alloy frame which provides a highly rigid case that’s resistive to electrical noise and other interference creating a stable, high quality sound.
Revel in authentic sound reproduction
With the use of S-Master™ HX digital amp technology, independently developed for Walkman®, the NW-WM1ZM2 and NW-WM1AM2 bring you stunningly faithful sound reproduction. The full digital amplifier further creates a rich and full-bodied sound, with the help of a high-quality lead-free solder.
Taking inspiration from the ground-breaking DMP-Z1, both music players feature an even stronger power supply than their predecessor models, both in the analogue and digital block.
The NW-WM1ZM2 and NW-WM1AM2 have upgraded fine-tuned capacitors – various FT CAP3 capacitors (High polymer Capacitor) and a large solid high polymer capacitor which offers large capacitance and low resistance. While an OFC milled block covering the digital block, allows both music players to bring you sound that appears to rise-up from silence.
Perfect Signal Integrity
To achieve a powerful and smooth sound quality, Sony has selected a thick KIMBER KABLE® to run from the amp base to the balanced headphone jack on the NW-WM1ZM2, much like the renowned DMP-Z1. This carefully selected component helps transmit high quality audio signals, leaving just you and the music.
The NW-WM1AM2 uses a low-resistance OFC cable which offers low distortion and superior channel separation.
To realise both music player’s evolutionary sound, a dual clock and fine sound register have been precisely placed within each Walkman®. For the first time, Sony has begun using a reflow solder containing gold, whose effect is significant in the overall improved sound localisation and wider sound space.
Get the most out of your music, whatever the source
The NW-WM1ZM2 and NW-WM1AM2 both integrate a DSD Remastering Engine where PCM (Pulse Code Modulation) audio is resampled into an 11.2 MHz DSD (Direct Stream Digital), giving you even more ways to enjoy your music.
With the NW-WM1ZM2 and NW-WM1AM2 you can also inject more life into your music by upscaling compressed music files in real time with DSEE Ultimate™. This evolving algorithm now offers even more benefits for CD-quality (16 bit 44.1/48kHz) lossless audio. By restoring acoustic subtleties and dynamic range, the user can experience a more complete listening experience.
Hear every note as the artist intended
Both Walkman’s® are also compatible with Balanced Connection and High-Resolution Audio, allowing you to experience your most loved tracks, just how the artist intended.
Music on the Move
The NW-WM1ZM2 and NW-WM1AM2 are now Wi-Fi compatible and run Android™ 11, giving you access to a vast collection of genres and artists, from all around the world. You can choose to either listen from your favourite music streaming and download services or connect to a PC to download tracks and playlists from your own personal collections, ensuring high quality sound playback.
All new optimised usability
With a larger 5.0” (12.7cm) display, both music players introduce a new smooth and responsive touchscreen that has been upgraded to HD (High Definition), optimising the user experience. You can also personalise your home display on the Walkman® Home Screen to suit your individual needs, making your Walkman® truly your own.
To ensure you can immerse yourself in your music wherever you are, both premium models give you up to 40 hours [1]of non-stop 96kHz FLAC High-Resolution Audio playback.
A USB Type-C® port features on both models, offering fast music file transfer and easy connectivity with a range of devices.
The NW-WM1ZM2 offers 256GB of integrated memory and a microSD card slot, while the NW-WM1AM2 offers 128GB of integrated memory and a microSD card slot, allowing you to take even the biggest music collections, wherever you go.
Sustainability matters
Sony’s products are not only designed to be stylish, but also with the environment in mind. Zero plastic [2] is used in the packaging material for the NW-WM1ZM2 and NW-WM1AM2, reflecting Sony’s commitment to reducing the impact of our products and practices.
Note to readers: On 17th March, Sony is providing a unique opportunity for any customer or enthusiast to ask the engineers behind our new Walkman models a question about the product or its story. To participate, please post your questions on Twitter using the hashtags #Sony #Walkman #AskEngineers by 17th February and Sony´s engineers in Tokyo will answer the selected questions in a video message. Alternatively, you can use the Google form below.
https://forms.gle/aaY9AY3sXQXtn5mT8
