Since the last update my camera won't transfer the photos - the wifi seems to make the connection but then nothing happens, anybody else had this, any ideas on how to resolve? Have cleared all the wifi on my phone, also reset the wifi on the camera, but not worked. Camera is an HX90
Hi @shirlthegirl21, welcome to the community.
Can you clarify the update was to the camera firmware, and the version you are using?
It might be worth re-starting both devices, if you haven't already, to see if that resolves the issue.
Thanks
Mick
