I have had a dsc HX300 for 10 years and I love it. Recently, however the viewfinder has come out of focus. Your aiBot suggested I reset the camera back to its factory settings. I did that but it did not work. Any suggestions?
Thanks.it worked. I knew it had to be something that simple!
