Hello everyone , can you please tell me how to rotate a video , and why cant i share it with some one else
i use a Sony Dsc HX60 CAMERA
thank you bob
Hi Bob,
I'll look into this for you and see if I can find out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
Hello @chester2409,
you generally can rotate videos with any video editing program on your PC/MAC.
Some smartphone editing apps might allow for the same, but I only edit on my computer.
Which codec are you using? Maybe you can't share the videos, since you used XAVC-S.
- Nic
Thank you for your help Spotted Woody in our garden yesterday , taken through the window
Hi Chester2409,
I agree with IamNic, you can rotate them using any app. How do you try to share the files?
Cheers,
The_Black_Rose
