x
Sony cybershot camera DSC-HX50
SOLVED
profile.country.GB.title
HeidiP
New
I have a cyber shop DSC-HX50 camera which I don’t use anymore. Should I remove the SanDisk SDHC Card from the camera before I give it away? Or are there any other precautions I should take apart from deleting all photographs ?
1 ACCEPTED SOLUTION
Accepted Solutions
Thalamus.
Champion
Hi HeidiP,
welcome to the Sony User Community Forum..
Yes you should remove the SD card or at least format the SD card before giving your HX50 away..
Also  you  may want to take a look at the following Sony guide on;-
How to reset a camera back to original factory settings..
3 REPLIES 3
Thalamus.
Champion
Hi HeidiP,
HeidiP
New
Thank you so much for your advice and for the link.
BW HeidiP
Thalamus.
Champion
You are welcome HeidiP..🙂
