I have purchased a Sony Rx10M4, and since I prefer to use NTSC system, for 60fps, i set the system to NTSC, when the default was PAL.
Now, I have that message "Running on NTSC" every time i open the camera, which goes away if I half-press the shutter button. It goes away entirely if i revert to PAL.
Is there any way to get rid of it?
Thanks
Not that I'm aware of. This message is always shown, if you change the setting against the standard setting.
