Setting Memory 1 & 2 - Just can’t get it to work!
I set the camera up for example: Stationary birds etc.:
Aperture priority f4
Drive Mode Continuous lo (3fps)
ISO AUTO
- focus C, Flexible Spot S
I then got to menu 1 - page 3 - select “1” at the top and press centre button on rear wheel.
Reset the camera for: Birds in Flight:
Drive Mode Continuous MID (10fps)
ISO AUTO
focus WIDE
Go back to Menu 1 page 3 - select “2” and press centre button on rear wheel.
As I understand it I should then be able to put MODE DIAL to MR and then press either left or right Control Wheel I should then be able to select either M1 or M2 and recall the stored settings - but it doesn’t work. When I select either M1 or M2 they are both the same settings.
Where am I going wrong? I’ve been at it for hours 😡
DOH!! 🤡🥴 Sony RX10M4
I am still really struggling getting M1, M2 & M3 to record sets of settings and being able to recall them when I want! I have tried dozens of times now and Avery time, when I recall them they are all the same, they have recorded the last set on settings I programmed into one of them.
It is driving me NUTS!
What I have dome is to set my most used set into the "A" and the second set for BIF into the M's.
When I want to change I just move the Mode Dial from "A" to "MR".
I cannot get any of the Custom Buttons to recall different sets.
I've made a video about this for the A7/A9 cameras. The principles are the same for the RX series, so perhaps it will help -
Thanks for that! It reminded me where I was going wrong! After setting the Mode dial to MR I was not then going to the wheel/L/R to select the memory I wanted!
Works just fine now!
I have since programmed a user set so that I can switch immediately from normal to BIF just by pressing the Focus Lock button - works a treat!
